Topic: coil-over users (Read 1887 times) previous topic - next topic
coil-over users
What spring rates are you using, what car and application?
FYI I'm looking for a rate comparable to stock for a TC.
__________________
Twin '85 TCs
White/ Grey 2-tone
coil-over users
Stock rate was ~415 lb/in up front and ~210 lb/in out back.
This would correlate to a ~115 lb/in coil-over spring in front and ~93 lb/in out back.
I currently have 275 lb/in coil-over springs in front with the factory springs out back. There is a definite mismatch between the front and rears.
The 275s up front are a lot stiffer than the factory springs, but they aren't really uncomfortable.
coil-over users
These guys have four choices, 12"/250s, 14"/175s, 14"/150s and no springs.
http://dynamicracingproducts.com/AutoPartsStore/product_info.php?cPath=1_18&products_id=214
As I understand it, 14" is a bit tall for a coil over spring?
Jeremy, what engine do you have?  Relocated battery?  Any other weight changes?
Thanks
__________________
Twin '85 TCs
White/ Grey 2-tone
coil-over users
I have the CFI 3.8L with all the options still installed. Battery in factory location. 12" springs.
coil-over users
400's, but im not goin for anything near stock rates ;)
coil-over users
Thanks for the feedback.
__________________
Twin '85 TCs
White/ Grey 2-tone
