Topic: Running a rear sump only pan? (Read 1426 times) previous topic - next topic
iI’m pretty sure any fox pan will fit just make sure it’s a stock replacement. Not for aftermarket Ks
the pan in the link is actually a front sump pan
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Nope won't fit. You need a Fox body dual sump pan. The pan from a 5.0 Mustang, Mark VII, and 83-88 5.0 T-bird and Cougar are all the same. You NEED one of those.
and 5.0 crown vics, lincoln town cars, and mercury grand marquis'.
1979 Ford Fairmont
[/B]
the canton widage tray is for a rear sump, and i think that alot of places call the dual sump a rear sump also, because the front sump really just is clearance for the oilpump
Quote from: thunderjet302;189183
I have a dual sump pan. Are you saying I CAN'T use a rear sump only?
How can I run a windage tray then?
thats why all the kits that u have to buy to run a 351w or a 428 in a fox come with a special double sump oil pan. if you could use the regular oil pan, that wouldnt be in the converion kit.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
i dont think ive actaully seen a rear sump pan, but you can get a windage tray from canton that will work with the pan you have!
Quote from: cougarman;189258
Is a 'rear' sump pan considered a dual sump pan as well?
yep, the front sump is more for show i think
I don't see your reasoning on that.
I think I will call moroso or someone of the likes and see what I can figure out.
