Topic: HO vs SO pistons: Only higher compression? (Read 1325 times) previous topic - next topic
Along with being forged and is that it?
Just gathering a bit more information.
both are 9:1. SO's are dished and take up the same overall volume as the two reliefs in the HO's
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
Sweet, thanks man, no need to step up to HO pistons then :hick:
The '86 HO has flat top pistons, with no valve relifs...
I found the specs for the SO to be between 8.4:1 and 8.7:1.
yes, with only a HO cam, you should be ok. anything bigger or better then a stock HO setup is when youll need valve reliefs
Quote from: 88XR7;189071
Unless you want to run a big valve head and a bigger than stock HO cam (like me ;) )
Quote from: Sick88Tbird;189074
83-85's were 8.4, when they went to sefi in 86, compression was raised to 8.9
On the E7 pistons the eyebrow valve reliefs are -5.5 cc
Just some info don’t know if it helps.
Quote from: grutinator;189098
That explains my malfunction.
