Topic: power door lock relay ? (Read 1678 times) previous topic - next topic
the ? is where are they located? evtm says under the seat.
i dont see anything. i have just gotten an 88 XR7. the locks
work from both sides to lock but you hear nothing on either
side if you try to unlock[from either switch]. judging from what
i have read it is probably a relay. i have an nos one for both
lock and unlock. any help is appreciated. thanks! -irv toms
If you have keyless entry the locks are controlled by the keyless entry module instead of relays under the passenger seat.
no keyless entry system--irv
actually, the manual says they are under the passanger seat.  did you look there?
they are near the hump under the passanger seat.
one relay is unlock.
the other is lock
They were under the pass seat on the '87 Sport I had...
