Topic: T.C. rear axle question... (Read 3336 times) previous topic - next topic
i installed a 87 t.c. rear axle with disc brakes in my 84. i took all the parking cables and brakets... even the pedal. my question is this , on the t.c. car the parking brake cables route on this small metal bar crossing under the drive shaft and the exhuast. well i have installed a 306, C-4 combo with an 2 1/2  H-pipe too. will the remaineder of my exhuast fit above the bar for the cables ?????? or will the exhuast go under the bar ??????
Just take the bar off, I had to remove it to fit my exhaust.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
then where did you route the emergency brake cables???????  are you running the 5.0 dual exhuast set up ??????
I just ran the cable under my pipe. I have a 3" single to 2.5" duals and the e-brake cable crosses right past where the pipe splits.
Garrett H.
Exhaust sound clip
Another clip
I took the bar off also.
Ran the cable under the exhaust.
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
Me too but ran it over top of the exhaust.
Quote from: dominator;189763
Me too, but mine was a factory 5.0/AOD combo. I used Mark VII rear cables.
hey can anyone show me some pictures of how they ran the emergency brake cable around the mustang type exhuast setup????
Still have the bar with the cables clipped to it(as factory)... 2 1/2" exhaust routes over bar... Actually it is wrapped with header wrap and the exhaust sets on the bar... No hanger on "H" pipe...
