Topic: Ever do something dumb and you wanted to smack yourself.... (Read 1376 times) previous topic - next topic
So I went out to the garage to start the snow bloweer yesterday just to make sure it worked before we got any snow:hick: . The 88 T-bird has been sitting for 3 weeks in the garage. Every week I check the oil and start it and let it idle for 15 minutes just to keep things *oiled* up. I've done that every winter when I put it away. Any ways I dropped the spark plug for the snow blower and it rolled right under the T-bird. I look under there and noticed a small oil spot about the size of the top of a soup can under the rear sump plug. I was like "wtf the motor was changed this year and the pan is new?" Well then I remembered something. I changed the oil back in September. When I did I didn't change the oil plug gasket. Well it turns out the oil drain plug is tight but the gasket is a one time use thing:hick: . So now it's going to leak a little till I change the oil in the spring. Ah the joys of doing something stupid when it's so simple not to :dunce: . It leaks so little that I didn't even notice that oil was missing when I checked before I started it. Oh well.
both those gaskets leak on my mark VII(two drain plugs) annoying isnt it? I'm not draining mine soon, stupid royal purple isnt cheap.
Quote from: daboss351;188634
Yep stupid easy to change too;)
Mines leaking Mobil 1. That's expensive stuff too:hick:
its funny cause i leave cardboard under it and it turns purple
Quote from: daboss351;188682
Well now you know how to dye cardboard ;)
hahaha thats a expensive dye! Almost 8 a quart!
Well gets your money's worth out of it. Dye lots of cardboard and do an art project ;)
10-30W ford motor craft synetic blend let it leak at $2.32 a quart i am pissed off my oil is leaking but oh well if it leaks to much i just spend a little on a oil change.
What is this drain plug gasket you people speak of ?????
I've never had a problem with that.
Lucky
Ford makes an updated version of our drain plug (I dont' remember the size or part #) that fits the old fox pan. The updated version has a rubber O-ring seated in  of the bolt, like all of the late model stuff. I installed these last time I changed oil and no more leaks.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
Full Digital Dash w/ twin Cyberdyne A-pillar gauges
245/50/16 Tires on Snowflakes
Engine swap - CA smog compliant
Quote from: 88BlueBird;188727
Well I'll be making a trip to the Ford dealer in the spring then :D
Everyday when I get to work.
1987 TC
i dont know how much this helps but when i had to get a new drain bolt gasket i would just buy a new bolt. should definately work for you four cyl guys though.
the gasket cost almost 3 bucks, itself
new oil drain bolt from autozone which comes with new gasket cost $1.00
