Topic: power seat electrical problems (Read 1582 times) previous topic - next topic
alright thought my power seats were froze so i took seat out greased track everything greased back up right tested track before i put back in car with batt charger it moved good fowards and backwards up down side side all works i hook switch back up it dont work fuse isnt blown get 12V on all ways of movement of the seat .......what is going on with this stupid power seat it all started when the thing was all messing up would move alittle then quit so i thought it was switch switch was nasty as hell anyways..that dident help so i thought track was screwd...i havent replaced harness think thats best bet or what? please help somebody!!!! or ima get the :beatyoass:
Did you check the grounds good? If you have power going in in all directions, it might just be a bad ground.
not ground not power i get power makes no seince
just because you have a "good 12 volts" doesn't mean you are getting the AMPERAGE that each motor needs. one single strand of copper wire will carry 12 volts but not any amps. check for breaks in the harness. or a short to ground maybe on the seat track. Here at the jaguar dealership we mostly find short to ground under the track a pinched wire. good luck hope this was helpful.
yeah im thinking about just pulling the whole harness when i get back home and replace it with the one i got with the switch Crusher sent me....where does the harness plug in to get its power :-?
The main seat harness plugs in under the console, then goes under the carpet to get under the seats. You already had the seats out, so you know where to hook them up there.
there is no fuse for power seats, a circuit breaker would be the safety link instead.
on the driver seat........
if you have 12v on the forward motor yellow/white and the red/white when the swtich is moved to forard, then you have an open circuit.
No one wire is designated at the "power lead" as both become the power lead depending on the direction of which the switch is moved.  The polarity is switched for reverse.  When activating this option and you do have power on both wires, you do have an open ground.
to test,,,
verify you have power on the yellow/white, jumper the red/white to ground.  Now move the  in the direction that makes forward happen.  If it moves,, you have just confirmed its an open ground.
all the motors have a couple things in common ,, the switch , circuit breaker and a ground which is the black wire.
See my DIY link for a diagram of the power seats.
