Topic: what can i do? towards MPG :) (Read 2587 times) previous topic - next topic
i know everybody is going for performance to increase HP and torque, i just wanted to know what can i do , performance wise , to increase MPG to the max, without touching the tranny!
Re: what can i do? towards MPG :)
For a 3.8. Dual exhaust is about the only thing you can do. I did that to mine and I got a small increase in mileage.
remove/bypass the smog pump.  surprisenly there was a noticeable highway mpg increase.  i can sometimes get over 30 mpg doin 75-80 for a few hours.  pretty nice  :)
but only 9 in the city
interesting.....only 9....thats crazy dookie..........
the exhaust....how much shud i go for like size wise......and also i want an exhaust system that isnt loud, because im gonna be mostly driving on the highway, trying to keep it as quiet as possible......what do u think lowcat?....or does anyone have any suggestions....shud i keep the stock system?.....any advice will be gladly appreciated since i just bought her !
If you tune up your vehicle first... new plugs and wires.  Also new filters, PCV, breather filter and air filter...  Just the basics.  I also recommend the "RESTORE" brand six cylinder formula with the oil change.  Get some efficency back.  It's about making it run good really... and keepin your foot off the gas!
:pics-stfu:
 Project Thread with pics
if you do put dual Exhaust and decide to do the True do not go with the 2.25 inch way to big for a stock motor. and  will kill your bottom end power trust me i know(learned from that mistake) and using the stank Hpipe sounds good . but isnt practical. unless you have a floor shift and a V8. do a custome job 2 inch all the way back. two cats (none high flow) the 3.8 likes back pressure and some stock style s to be quiet and some more pressure. you should be set.  if you want you could upgrade the gears in ur 7.5 but since ur gonna be on the highway. i thinkk 3.73 may be to steep for you car and could wear it out with the Rpms. at a constant. i know mine was at about 2k at 65-75ish not to bad.
Good luck  and the tune up is a great idea. get some nice auto lights
Quote from: Dookie86
you need a tuneup bud. I get at the least 15mpg, and that's city driving+hauling ass everywhere
Quote from: blackwidow
I recommend just stock 2" dual exhaust for an 88 tbird or cougar for 4 reasons
1.)An h-pipe or something like that is overkill for a 3.8
2.)The stock dual setup leaves you with enough backpressure to run right
3.)If you install it yourself it is much cheaper then a custom dual exhaust.(I paid about $100 for 88 cougar tail pipes and intermediate pipe.)
4.)With dynomax ultra flow lers it sounds pretty good for a v6.(That is what I have and the sound is good. At highway you can barely hear it but during acceleration you can hear it with no problem.)
I had the lers laying around so to put dual exhaust on my cougar cost me about $110 all together. I went from an average of about 23 mpg to 24.7 mpg after this.
Thanks alot guys for the idea and help! i think im gonna do that :) dual all through!
