Topic: 3.8 head gasket ? (Read 1061 times) previous topic - next topic
3.8 head gasket ?
What gasket would be better to use on these engines.The reg felpro, or the PermaTorqueMLSTM.
or other brand.
3.8 head gasket ?
I used the PermaTorque Blue Felpro's when I repaired my head gaskets.  They work well because they seal any surface imperfections on the block or heads.  The MLSTM require a perfectly smooth sealing surface. You would want to get the block and heads surfaced if you plan to use the MLSTM.
Clean the block and heads really well with a razor blade and use the PermaTorque Blues with new torque to yield bolts
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
3.8 head gasket ?
What year 3.8? I'd go with Felpros or Ford ones (which I think are Felpros anyways).
3.8 head gasket ?
Quote from: 88BlueBird;187546
They list 2 cheap and double the price ,So is cheap the way to go?,I have not pulled the head yet,I owened two 3.8's before never had a problem,I know about the bolts,I guess I'm askin what you all have best luck with.Anybody got a part # I could use?,That would simplify it.As you can tell I am not a 3.8 guy.
3.8 head gasket ?
Buy the high end Felpro ones that are Permatorques and not MLSTM.  Don't buy the off brand ones.
1988 Thunderbird
