Topic: Good intake to use for 5.0 carb'd (Read 1241 times) previous topic - next topic
With everything on will it clear a stock hood?
That is good #'s on it.
i don't see that clearing a stock hood with an aircleaner.
:pics-stfu:
 Project Thread with pics
Quote from: blu84302;187500
Thats the only problem with the intake.
But then again, If your using this intake, your probably more concerned about power than cutting a hole in your hood.
Don't get me wrong, I'd love to have it. But I can see alot of issues with it.  TV linkage being one.
But I'll probably have to cut a hole in my hood when i get to the aircleaner install. And my intake doesn't look as cool as yours.
:pics-stfu:
Quote from: blu84302;187520
Yeah, I used my stock throttle cable from the CFI and made a custom bracket to support it, it works great.
What do you mean by TV linkage??
i'm running the edelbrock rpm intake. but i also have a C-4 to handle all the power. i have seen too many stock aod's tear up down the track from a very weak input shaft. you can spend a few hundred and beef up the aod if you really need the gas mileage. But then again I DIDN"T BUILD MY CAR FOR GAS MILEAGE !!!! did you install at least a trans cooler ??? Even though i work at a Jaguar dealership i see lots of trannys come in with burnt fluid . (other fords , not jaguar)
TV=Kickdown rod/cable.  If you're running an AOD it's a must.
I'm using the factory Tranny cooler for my AOD. ;)
:pics-stfu:
the new intake eats the competition in the 4000-8500 RPM range.
With that high of an operating range, it's probably gonna make your low end torque suffer mucho lotso.  Not to mention the things you'd have to do to an AOD to get it to spin that high as well as a matching cam to see the benefits of it and a torque converter that stalls  around 5,000 RPM.  NOT A STREET INTAKE.
Like the site says :
Designed for highly modified SBF engines
Quote from: V8Demon;187587
Ive seen driveways big and long enough to handle that,really sickning,where do the people get the money?
