Topic: Setting timing? (Read 883 times) previous topic - next topic
Setting timing?
Pull the plug on the distributor harness, start the car, set timing, turn the car off, re-install the plug, then start with new timing, correct?
Setting timing?
um yeah
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
Setting timing?
Quote from: 88XR7;187002
Pull the plug on the distributor harness, loosen dist hold down bolt, start the car, set timing, turn the car off, re-install the plug, tighten dist hold down bolt, then start with new timing, correct?
Forgot something ;)
Setting timing?
Eh you could prolly consider that part of the 'set timing' process.
Setting timing?
Quote from: Chuck W;187007
Forgot something ;)
Bah, non sense, REAL men do it while it's bolted down:hick:
