Topic: So, she runs... (Read 2205 times) previous topic - next topic
So, she runs...
Most of you saw this thread...http://foxtbirdcougarforums.com/showthread.php?t=16560
Where I thought I was having sensor issues and whatnot.
Well, this morning I went out and grabbed the battery to throw on the charger and decided to re-check my firing order for the 5th time.
Turns out, I hate the firing order correct, but going clockwise on the distributor the way a chevy would, which is what I'm used to....
:hick: :burnout:
She started right and up ran purrfect...
I'm happy as ever, and if anyone wants to come down to Florida and :beatyoass:, feel free to:shakeass:
So, she runs...
Well, incase anyone cares...-_-
Awhile  ago, I went to the track, ddin't run due to a slight oil leak, 1 mile from the house, normal driving, rod knock.
Sooo, blocks out, front clip is off, have an HO shortblock going in and I'll be throwing me E7's on, maybe getting em ported, we'll see.
Hooker headers are going on (Can't beat free) along with a H-pipe.
That'll be it, other then a shift kit and gears later on.
So, she runs...
Wow so much for getting it running finally! You take it for one drive "well that was fun time to replace the motor" :giggle:
Should be fun though, more power always = good.:D
So, she runs...
You have no idea how many 5.0s I've seen run for years with a rod knock. It's funny how it doesn't kill them right away.......
So, she runs...
Quote from: thunderjet302;193545
Ehh, it motivated me to do the swap.
Only go fast goodies for this period are Hooker Shorties and mustang H-pipe.
Anyone hear anything about running a 5 speed computer on an auto?
So, she runs...
Tomorrow I am picking up my block early in the AM.
Goal: to atleast set the engine in the bay, I do have to prep the bay so I can't just plop it in and be done in 5 minutes. IF, I get the engine bolted onto the mounts and onto the transmission, I will be exstatic. That would only leaving, wiring harness, heads, transmission crossmember, filling fluids and welding up the new exhaust and that about covers it.
So, she runs...
Wow, some time has passed since I last said anything...
I didn't get the block on 12-28 like I said, when I woke up that morning with a 103 degree fever, my body didn't want to function much:hick: and the block wasn't done anyway.
Well, I've been told it's done and he will bring it by on wednesday, I hope so, I need her running now that I've found a job. Same goodies, headers and de-catted mustang h-pipe, I alreayd have my 91 DA1 computer and 19# injectors, so I'm good to go.
Today consists of cleaning the engine bay and sweeping some leaves from around the car so I can move my  engine hoist around and some painting in the engine bay along with maybe a little bit of paint where I removed my pinstripes.
So, she runs...
Hope all goes well with the swap! Post some Pics when you're done,  Or a Video would be better;).
So, she runs...
Quote from: Triple-X;202242
Yea, right now I'm taking a break from cleaning up the engine bay, gunky, grimey, poopy, oil/grudge deposits are a pain in the arse.:shakeass:
I am one dirty Irishman right now:hick:
So, she runs...
Yep,good luck.It should be pretty easy to get finished.I think you'll love it.Keep us all posted on the progress.Man,I love this stuff.
So, she runs...
Flashback to July of 2000.  Had the same thin happen.
So, she runs...
Block will be here in a couple hours.
In the meantime I've been degreasing and degreasing...:hick:
So, she runs...
I had a slight knock at idle... Had an extra motor and decided to throw it in while I get a new transmission. 4 of the rod bearings were messed up...
So, she runs...
Well, it's been a bad night for me.
It's 11:06 and still no block...
Atleast I got to sit down and talk with my ex-gf, still love her, was quite refreshing.
Umm, I got the tranny back up on its crossmember, and degreased the engine bay, a/c compressor, and power steering pump...
...I wouldn't be able to drop the motor in since I broke my tranny cooler lines and have to run new ones, but I'm tired of this run around about getting my block...
So, she runs...
Quote from: 88XR7;202668
That sucks....
