Topic: throttle (Read 2390 times) previous topic - next topic
throttle
im buyin a edelbrock manifold and what should be a good size for the throttle 70 mm or 75 mm and do u feel a big difference betwween those two
Re: throttle
Whats your engine combo???? Unless you have something really wild, 65mm is plenty...
Re: throttle
need to know more about your motor.
Re: throttle
its stock but im planning on alot of things cause i want to know will i notice a difference in this manifold
Re: throttle
I have heard that anything over 60mm for a stock motor, will make you bog down ibgtime. Switch it out after you install a H.O. camshaft.
Re: throttle
MY motor has a 65MM TB, I cannot see your stock one needing anything greater than that!
