Topic: Roll Bars for T-birds (Read 3638 times) previous topic - next topic
Here's a functional link.
Quote from: JeremyB;186201
Both work the same on my computer?  But thanks for the help, I try to do my best.
TED
A Mustang cage may work depending on how the main hoop is done.  When I made mine I started with a Mustang main hoop, but I needed to kick the lower portion of the bottom of it in a few degrees to get it to fit.  I don't have any good pics of it to show what I mean though.
looks like a decent price. ive only seen one S&W kit, and it fit well for a pre-bent unit. havent installed one.
ways to weld the top -
  • cut roof off, weld cage/bar, re-install roof
  • cut holes in roof, weld cage/bar, patch roof
  • tack tubes together, drop complete unit, weld cage/bar, and lift back into position
  • close your eyes and pray
for a simple roll bar, i would recommend the third option :evilgrin:
it takes some plannin ahead, but is workable in most cases. one example -
  • cut round holes in the floor
  • place foot plates over the holes
  • fit cage/bar parts that will be impossible to weld completely while in place
  • tack together
  • slide plates out to reveal holes in floor
  • lower cage/bar thru holes
  • weld
  • lift cage/bar back into place
  • slip foot plates back under cage/bar
  • weld foot plates to cage/bar and floor
  • fit and weld in the rest of the cage/bar parts
YMMV :hick:
Quote from: Chuck W;186206
Sorry Chuck I was mis-leading with my first post.  When I said I was going to order one for a Mustang I meant the Mustang I just purchased, not my T-bird.  These guys do make them special for T-bird/Cougars and if the first one works out well maybe I will order one for the T-bird also.
I just purchsed a 1988 Mustang Coupe and I plan to do another Cadillac 500 swap into this.  But I want to start out with the roll bar and subframe connectors first this time.
It's a cute little yellow car, and will shave about 600 pounds from the T-bird.  Also keep me from cutting the bird up anymore.  Mustang Coupes are getting very hard to find in the Northwest and the prices are going way up.  This a 2.3 car.
TED
I bought an S&W 8 pt for a Fox T-Bird in 2002 when I was in the process of building my 87 TC 460 for IHRA Stock Eliminator Racing.
Never got around to installing it, so I have no valuable input as to whether or not S&W has got their act together regarding Fox T-Birds cages fitting correctly.
I don't know if I will ever install it now.  I really like getting in and out without the hassles.
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
I also bought their cage for my 86, it turned out great, a real quality piece all pre bent and notched. I got D.O.M. steel instead of the chromoly piece though (kinda expensive)  The shipping was almost as much as the cage.
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
Quote from: Cad-T-Bird 500;186218
TED
At least the Stangs have a sump in their tank so they don't die when floored with less than 3/4 tank :hick:
I have a S&W 10pt installed in one of my TC's. It fit's quite well in my opinion. As for the up top welding; we have the main hoop attached at the front of the backseat ledge. We just tacked the halo and rear bars, then lowered the whole thing to the main floor and finish welded. Raised the assembly back up to the ledge and welded to the previously installed floor plates. Done.
TC#1- 2.5T- 10.14@134....9.76@138 with a 50shot
TC#2- Turbo BBF project
TC#3- parts car
