Topic: 32VFoxBird...I gotta ask ya... (Read 2425 times) previous topic - next topic
just what is the name and shade of that paint in your engine bay?
and what is the areas I've marked with the question marks for?
That's gonna look bad-ass when it's all done...You said something about a Navigator engine...would that be a 5.4? :evilgrin: :D
the color is 03/04 mustang mach 1 azure blue. as far as the question marks in your pic, i dont know what you're asking me really. those spots are an open channel from the factory that i sealed off with sheet metal and bondo.
and yes, ive picked up a DOHC 5.4L navigator motor to use. http://www.foxtbirdcougarforums.com/attachment.php?attachmentid=13726&stc=1&d=1193433555
1979 Ford Fairmont
[/B]
I guess the ? on the left would be the air box area, the ? on the right would be the battery area.
Quote from: 32VFoxBird;185903
Is that going to fit under the stock hood ;)
Quote from: thunderjet302;185942
hell no. the 4.6 wasnt going to fit either.
1979 Ford Fairmont
[/B]
its got one cam per head right?  why is that called a dohc?
2 heads, 2 cams...dual...overhead..cams ;)
they tend to refer to the Cobra engines as 4-cammers..or quad cams
DOHC means 2 cams per head.
1979 Ford Fairmont
[/B]
Quote from: 32VFoxBird;185958
Well perfect time for a shaker hood a la 428 Cobra Jet style ;)
DOHC = 2 cams in each head. each head has an intake and an exhaust cam. 4 cams total. 2 intake valves and 2 exhaust valves for each cylinder. 32 valve engine.
SOHC = 1 cam in each head. each head as one cam that handles both intake and exhaust. 2 cams total. 1 intake valve and 1 exhaust valve per each cylinder. 16 valve engine.
then theres the 3 valve engines. i "think" they are all SOHC.
~John~
Quote from: shame302;186161
Yeppers. 2 Intake - 1 Exhaust
I coulda sworn a recent Hot Rod or Car Craft article had something about putting the 4.6 into fox-bodies and getting it to fit . .  but don't hold me to that . . gotta see if I can dig up the article.
1988 Thunderbird Sport V8 - only 1 previous owner, and 110% bone stock so far... and sold to Nate!
Quote from: King_V;186438
the 4.6L wasnt a problem. it was the 5.4L that'll test your patience.
1979 Ford Fairmont
[/B]
Forgive my lack of knowledge here...I thought that the 4.6 and 5.4 were roughly identical in size?
About all I know of modular engines is that they share a few parts between them. :hick:
no, they're not. the block, crank, rods, intake, and timing cover are what separate the two.
4.6L = 281ci
5.4L = 330ci
1979 Ford Fairmont
[/B]
