Topic: HELP!!! QUICK!! Starter Problem (Read 1694 times) previous topic - next topic
ALright I just changed the dam heater core and took off the whole dam dash..
Now I try to start the dam car and u don't even hear a kick.  Everything works besides that starter in the car :S So Do I have a bad starter, but if I did wouldn't u of heard a kick or a noise atleast?
Please Help because I'm basicly stuck from work till Ic an get the car started...
.: Lastest :.
ignition cyl. wires under dash
fuses
battery
starter relay
pull the starter and run it direct to see if its still good
Which fuse is it :S?
I checked all the 15 20 and 30 and theres even a 4 but is it one of those big ones?
Battery is fine
Starter Relay where is that located?
.: Lastest :.
the starter relay is on the passenger side inner fender above the ignition coil, it has two brass bolts/nuts on it. i cant see how messing with your dash wouldve affected it but doesnt hurt to check since i see the bolts come loose on them. they have a few fusible links to them also but cant remember what they are for atm
It was the column Shifter linkage, was never in park...
Simple error I guess now I feel stupid :-p.
Sad thing is I still smell anti-freeze for the first 30 sec every time I start the heater...
.: Lastest :.
You probably got some antifreeze in the heater core box.It'll eventually go away.Double check all the hose clamps and keep an eye on things for a couple of days.
glad to see the problem was solved, i never wouldve thought to check that lol
