Topic: Speaker Problems (Read 2097 times) previous topic - next topic
Speaker Problems
Ok so I bought new speakers for my 87 Thunderbird. The car had a standard cassette deck originally nothing fancy, so that means no premium sound as far as I could tell. I installed the new deck and have moved on to the new speakers. But I have hit a problem. The stock speakers have a weird connector with four wires going to it! I have found no adapters for it nor have I ever seen four wires run to a single speaker. What do I need to do hook up the speakers? I was gonna cut and splice but I have no idea what the wires are.
Speaker Problems
Cut and splice, take two wires and put them together, do the same to the others, put them on the positive and negative on the speaker, if theres no bass they're backwards, its basically trial and error.
I did it for the doors and rear deck and its better than stock, I'm going to run a four channel amp to them once I save up enough moolla.
http://foxtbirdcougarforums.com/showthread.php?t=14461
Speaker Problems
cut and use like a 194 light to se what is + and what is -  think with the 4 wire setup the other set is supposed to got to tweeters  bout don't really know just going off what i know from newer cars.
