Topic: Milan Dragway 10-24-07 (Read 2279 times) previous topic - next topic
I have watched this site for some time, and it's predessor for years.  I finally have something to report.  I have attached a PDF file for the time slip.  If you unable to open it, it ran a 13.035 at 104.47, with a 1.941 sixty foot.  While not a Nubie to drag racing, the learning curve of how to get a stick shift car, with a handling supension down the track, without stalling, missing shifts, or hitting the rev limiter, was a humbling experience.  I was pleased to be able to put it all together on the last run.  It was a cool night, in the low 50's with a altitude density of 800'.
The combination is a 306, with '69 casting, ported by Power Heads, GT-40 intake, 1 5/8 Long Tubes, Jay Allen Camshaft, Z-spec T-5 and 3.73 gears.  The car has not been gutted, all accesories are in place and working.
The car is a dream to drive, thanks to Jay Allen.  I have taken the car on two Power Tours.  The last one it got 20.5 MPG over 1,800 miles, with a best of 24 MPG.
Enough bragging.  I have to credit this site and Eric's Cool Cat's for posting the information necessary to complete the modifications and enhancements to the car over the past 7 years.  Without it, the car would not be anywhere close to it's current configuration.  I have a number of pictures I would like to share, if anyone knows how to downsize them, to get them to post, please let me know.
Welcome! Nice Bird, but you have to give us some pics and specs to drool over ;)
I added you to our Top 25 ET List BTW.
Thanks Mike.  I bought the body side moulding trim tape from your earlier this year (which worked great!).  I do have pictures, but they are far too large for this format.  If you know how to resize them, let me know, or I could E-mail them to you and try your hand at posting them.
I originally purchased the car with the intent to part it out, but discovered it was incredibly solid under some rust scale.  It was a base Bird, with the S/O 5.0 and a rod knock.  Typical grandpa car.  I disassembled the car down to the shell.  The body is stock, but the only orginal mechanical parts on it are the a/c compressor and the blower fan.  The interior is '88 Turbo Coupe/Raven (this includes the sterring column).  I have done many interior mod's on the Cool Cat's site (buttstuffog instrument cluster, w/ 4 cyl tach converted to 8 cyl, 200 KPH Speedo converted to read miles on the odometer, Trip Minder, Taurus heater controls and cup holder).  Brakes are disc 87/88 Turbo Coupe, front and rear.  They have been upgraded with pads from Maximum Motor Sports, braided steel lines, MkV11 front calipers and Crager's cryo drilled/slotted brake rotors.  Sub frames, strut tower brake and k-member brace.  Rear lower control arms from Maximum Motor sports. Sway bars, 87/88 Turbo Coupe.  15:1 steering rack.  Lowering springs from Eibach (I think they were the last set Summit had).  3G alternator, 3 core radiator, dual electric fans.  It was painted 5 years ago, the original Reggata Blue, with a base/clear.  Of course there were many itterations of the car, prior to it's current configuration (Fuel Inj to Carb to Fuel Inj), 8.8 w/drums to disc, three different engines, couple transmissions and clutches.  It's been a great project (thankfully not a daily driver).  Thanks for the interest.
Man that sounds like a sweet ride! Glad you liked the trim BTW. Email the pics and I'll post them up.
Thanks Mike, I will send some off to you.  I appreciate it.
