Topic: Taurus hvac swap (Read 2158 times) previous topic - next topic
Taurus hvac swap
I have the auto climate control setup, will the electric style taurus
hvac control swap over?
 :dunno:
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
Re: Taurus hvac swap
Only way to be sure is to check the plugs at the back, but I'm thinking it's different.
It may be possible to swap that over to 1994-97 Cougar/T-Bird style ATC, with a rotary  on the left and push buttons for the selectors and digital display....but I've never tried it.
