Topic: Tubular K-Member Input Needed! (Read 27956 times) previous topic - next topic
Reply #90
Quote from: 83-88T-Bird Guy;186272
I was curious as to why the decision was made to use the 83-84 T-Bird /Cougar dimensions?
From what I gather it is replica of the K that is in his car. The shop that built it is (or not) reproducing them.
Reply #91
To be clear, I'm interested in a K that will work on my (two) '85s.  Still waiting for pictures.
__________________
Twin '85 TCs
White/ Grey 2-tone
Reply #93
Posting a link to an old link containing incomplete information doesn't get one any closer to answering the unanswered questions the original link failed to answer.
__________________
Twin '85 TCs
White/ Grey 2-tone
Reply #94
This will not work on a 87-88 T-Bird??? or will it?
Not trying to be mean i plan on getting a 88 TC in the next 2 years and i don't mind giving UPR some money but i want a picture of it in a 87-88 Bird or Cat.
No matter what i think we should save as many 83-88 T-Birds and Cougars as we all can afford.
Reply #95
It won't and that's what most of us are getting at.
Reply #96
It will work
*BUT*
You would need to convert to Mustang-style motor mounts and swap to the shorter Fox Mustang/83-86Tbird control arms.  Which is offsetting the cost of the unit.
Reply #97
How could you only make it fit 2 years when the UPR one fits 79'-95' sounds like the frame is the same for all years?Check out this deal this is where I bought mine and free shipping.
https://www.coolblueperformance.com/index.asp?PageAction=VIEWPROD&ProdID=22
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #98
Quote from: 347Thunder;186792
We're not talking about Mustangs, and you obviously don't know the differences between the 83-86 and 87-88 Tbird/Cougar front suspensions/motor mounts.
No one said it wouldn't bolt into the car on an 87-88, it's all the other things people would have to change to use it on those cars.
Reply #99
So you would replace the complete front end and you would leave the stock py motor mounts great idea :screwy: and for the suspension why just replace all the front end parts and want to leave stock worn out parts save your money and leave it all stock.Do it right the first time don't cut corners :burnout:
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Reply #100
omghi2u2 :confused:
Reply #101
Quote from: 347Thunder;186802
Well let's see.  Alot of guys have already replaced all that stuff on their cars, and I guess they should just spend that money again? THAT is :screwy:  If a guy was starting from scratch, then yeah, but the guys who are speaking up are the ones who have already spent the money on said other parts.  Having to redo all that work makes the $300 K-member now a $600 proposition or more by the time you replace motor mounts and control arms.
Besides...there are other options besides the "stock py motor mounts", which some folks already have.
This coming from the guy who used a POS UPR K-Member.  Talk about cutting corners.  :rolleyes: I wouldn't use one of those things on a s rolling chassis.
Reply #103
Anyone in the vicinity have an 87-88 K-member they'd like to donate to Ron?
Reply #104
... my Birdie was sent to the crusher a couple months ago.
