Topic: Tubular K-Member Input Needed! (Read 27580 times) previous topic - next topic
Reply #60
I would only want one if the control arm points were raised to correct the geometry of a lowered car.
Reply #61
Quote from: EricCoolCats;184320
The company is in Michigan...it's a private builder, not a large corporation. Shipping to Canada should not be an issue, nor should pickup at their location. All the specs for this K-member were taken directly from a 1983 Thunderbird so we're talking Mustang-style motor mounts, and probably stock Fox Mustang/T-Bird/Cougar A-arm lengths.
I was getting all interested in this idea of k-members specific to the T-Bird/Cougar until I read it would be based on the 83 Bird dimensions.
Just me thinking out loud here, but wouldn't it be more beneficial to use the 87-88 dimensions and longer LCA?
My reasoning is that we can use our longer 87-88 LCA ( as well as 94-95 Mustang-LCA) to get the factory wheel track with the option of using Fox Mustang lowers if we want to use 3/4 inch offset wheels for whatever the reason.  Allows us more flexibility in suspension/wheel choices. ( The Fox Mustang guys can't do that)
I am trying to put 2 1/8 inch Kooks 460 headers in my 87 TC and I will have to cut/reweld with gussets on the factory k-frame.( mainly because I want to use my factory coil springs)
Would be nice to have a tubular tho.
Make the control arm dimensions the same as the 87-88 as well as coil spring buckets and I will buy one.
Alan
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
Reply #62
Tbird guy that is a really great Idea.  Add to that raised control arm mounting points and the option to lower the engine, something tbird guy could utilize being a big block guy.
Reply #63
Yeah, it would be great to lower the engine even more, but header clearance is more important right now.
I dread the idea of hacking up my k-member more than I already have.
Would be wonderful to run the 460 Victor/ Dominator carb set-up.
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Reply #64
Quote from: 83-88T-Bird Guy;184946
Alan
god your car excites me!
Reply #65
Those wheels look nice on your TC where did you get them???
Reply #66
Quote from: Carpimp1987;184992
Check out the following links:
The beginning:
http://www.foxtbirdcougarforums.com/showthread.php?t=11867
The follow-up:
http://www.foxtbirdcougarforums.com/showthread.php?t=14296
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Reply #67
[SIZE="6"][COLOR="Red"]PLEASE SEE SIGNUP SHEET NOW POSTED IN VENDOR'S SECTION HAS ALL UPDATED PRICING[HTML][/HTML][/COLOR][/SIZE]
Reply #68
As mentioned, pics are going to help this along quite a bit.  People are going to want to see what they are getting (or close to it).
Reply #69
Quote from: Chuck W;185612
I totally agree!
Would be nice to see how the k-frame tubes slope down after the frame rail bolts on the passenger side so I can get an idea if my big 2 1/8th inch Kooks will clear....especially the # 2 cylinder.
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Reply #70
Just bought a pair of sn cobra lowers for the front. I'm in if it's based on an 87-88 k member
Reply #71
still waiting on weight figures
Reply #72
will factory arms work on it or do we have to get Tubular?
Reply #73
Quote from: cougar86_89;185727
Quote from: EricCoolCats;184260
The K-member would be available with optional spring perches so that you could use stock springs and stock A-arms (no coil-over conversion).
Read, mang.
Reply #74
QUOTE]
x2
