Topic: Tripminder problems (Read 1729 times) previous topic - next topic
Tripminder problems
Ok, first off before everyone starts giving their two cents, let me give you a few details.
I have the tripminder installed, all the wires are in the right place, checked and double checked.  However when i turn my car on i get nothing.
I checked the tm before i installed it and it worked.  So my first thought after checking the wires, again, is bad connection.  I know that computers are delicate, but when there is a connection issue there arent many other options.  This being said i unplugged and replugged in the tm.  Low and behold it comes on.  Now is says "12:00 reset".  This isnt the problem though.
The problem is, when i turn the ignition switch off and back on the tm doesnt come on unless i unplug it and plug it back in again.
Any suggestions before i take it apart and start cleaning connections would be great.
Thanks a bunch!:birdsmily:
[SIGPIC][/SIGPIC]Project Twlight Venom reaching 65% completion.
Tripminder problems
This is just a guess, but I'd say you've got your "constant power" and "power in ACC" wires switched around...
Tripminder problems
If that was true wouldnt it be on ALL the time then? Its memory would also be lost every time you turn the key off.
Tripminder problems
No, it wouldn't be on all the time. The tripminder requires power on both circuits to come on. If you have power on one circuit but not the other it won't come on. The memory wouldn't necessarily be lost (meaning it might be lost or it might not be lost)  every time you turn the key off because it's still getting power through the acc circuit (which is hooked up to constant power). He has to unplug it and plug it in again to get it working, so we don't know if it's losing its memory anyway.
Tripminder problems
not to steal the thread or anything but when I turn the key off with mine it stays on for about a minute or so then turns off.
Tripminder problems
Confused with mine as well...  perhaps there was a few different wiring setups...
my dimmer does nothing to my tripminder...  how can I test to see which wire SHOULD be for the dimmer circuit?
1988 Thunderbird Turbo Coupe
Tripminder problems
anyone have a tested and trued wiring diagram that works well with a trip install to end all this confusion?
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
