Topic: 3.8 V-6 (can Anything Be Done!!!!!) (Read 3837 times) previous topic - next topic
Can anything be done to bring out some kind of performance in the carbed 83 3.8V6?  Headwork?  Cams?  etc?
Its not worth it. That motor is like 112hp stock, I doubt you would even get 130 out of it. They are what they are, an economy engine for bigger cars. They replaced the 3.3L 6 cylinder with its almighty 85hp and the 4.2L v8 I think as well, which only had 120hp itself.
They got decent way later in their life. The SC 3.8 was a torque monster and the split-port 3.8 had up to 205hp, but the older ones...meh.
http://www.foxtbirdcougarforums.com/showthread.php?t=13812&highlight=3.8+rocker
http://www.foxtbirdcougarforums.com/showthread.php?t=13026&highlight=3.8+performance
http://www.3.8mustang.com/
http://www.moranav6racing.com/
http://racerwalsh.zoovy.com/c=K4fI3L...ory/6cylinder/
http://www.supersixmotorsports.com/
Is their anyone on this board who actually is a fan of that motor?
I like the split port version. So much I'm going to swap one in.
I'm not a fan, but i have one.
the only thing you can do with that motor is sit around and wait for the head gasket to blow. and it will sooner or later
Quote from: daminc;184239
thats bs,, folk lore,,, bla bla bla.  Too much hoopla put into web sites and fraidy cats back in the day passing rumors about the "new" aluminum head causing all that.
Yeah, im a little familiar with the motor:D  I would be an idiot to say i like them but i do know them front to back.  The older ones just dont get enough air.
the better 3.8 is the 88 version and far better would be to install the 4.2l short block stuff into an 88 year 3.8.
I really dont think im comfortable saying the 4.2L crank works out in an 87 and down cfi 3.8.  its complicated but ill leave that long story off line for now.
now,, what you can do............
see my diy link
If it was a SC 3.8 then i am fan of it otherwise don't waste your money on it other than to keep it running and maybe a K&N fliter at most.
CougarSE has an 88 3.8L.  I've never drove it but what he did would probably be the best bang for the buck.  He put a T5 from a V6 mustang behind it.  I'm sure you'd see a big jump in performance from that and some suspension work.
:pics-stfu:
 Project Thread with pics
Sorry, I should have said that differently. my 87 head gasket went twice,and some friends had the same problems. I should have said, there's a possibility of head gasket failure with these motors. some do and some never will
ford v6 engines of any kind are awesome!!!!!
I've had 3 with the 3.8.  I was completely happy with the 85 Cougar.  The 86 Bird doesn't seem to have the power that the 85 Cat had.  The 92 Bird blew both head gaskets resulting in a new engine.  The new engine in comparison to the 85 and 86 is a hot rod!  Easily smokes the tires.  I probably would not buy another one with the 3.8.
I really like the 4.0 in the new Mustangs.  But I hear they are not great on gas.
Armed Forces Car Club
Eastern Sierra Chapter, California
WEB:  armedforcescarclub.com
Quote from: LJS30;184199
Dude, read the first 2 links I posted;)
Quote from: JeremyB
Still looking for a good car to put a motor in here....
i had an 83 cougar with the 3.8 c-5 combo, all i did was replace the carb with the holley 2 bbl from jegs. and it ran alot better. there is a company out there that specializes in the 3.8 cyl. heads for the 3.8 make some more power. you could swap rear ends out of a turbo coupe, hoping for some 3.55 locking.maybe even swap out the c-5 valve body for one from a c-4 performance one. deep pan for the trans. but that is about it. maybe a shift kit.
Quote from: V8Demon;184338
I can't find a nearby car with an unmolested wiring harness.
I'll try looking a little harder when the T-bird gets painted/rebuilt rear.
