Topic: changing cfi to efi (Read 1424 times) previous topic - next topic
changing cfi to efi
changing cfi to efi. im running it to a problem . do i have to take the dash apart to change the wiring harness?:mad:
changing cfi to efi
No.
The harness can be fished out through the hole in the firewall.
You will have to find the ground wire and the ECU relay that are attached up high on the pass side kick panel area in the interior though.  Once those are loose, you just fish the harness out.
changing cfi to efi
thanks ,never done this before .found ground wire,computers out .
changing cfi to efi
both are efi,, not sure what you mean or what motor your going to.
staying v6 but want 6 injectors or you talkin about going to a v8?
changing cfi to efi
jc ive never swapped cfi for efi ,its a 302 (.040) we got it the valves were burnt gess the shiznitty cfi cuased it,plus where gonna change the cam later shorties h-pipe flowmasters .
changing cfi to efi
thanks drew but we already have everything .about a week after this was rote we purchased a intake injectors for $150 then we got an engine harness for $100.the intakeis an h.o. thanks for the reply
