Topic: aluminum 4.6L DOHC motor (Read 868 times) previous topic - next topic
need to sell this motor to buy another one
*lightly honed '95 teksid block from mark 8
*turned .25mm mark 8 cast 6 bolt crank
*stock mach 1 rods and pistons (under 3,000 miles)
*sealed power rings
*new bearings throughout(dont remember the brand)
*rotating assy. balanced with stock flexplate and balancer from 95 mark 8 by Harris Engine Grinders(shortblock assembled by TSS)
*new tty main cap bolts
*'01 cobra heads w/ 3 angle valve job (done by Joe Halliday)
*96-98 cobra cams
*'99+ timing cover
*'95 mark 8 water pump, pulley, chains, tensioners, and guides
*01 continental cam covers and coil covers(black)w/ new spark plug grommets
*t-stat housing
*mark 8 coolant crossover tube
*03 cobra/mach 1 exhaust manifolds and h-pipe
*block separator plate
*stock motor mounts
*2v oil pan
*new HV oil pump/pickup tube from TVF
*stock 3-bolt starter
*new MLS ford head gaskets and tty head bolts
*stock water/oil filter housing
*full set of stock lash adjusters and rockers
motor is already assembled. i have roughly $2400 into this.
$2,000 OBO
1979 Ford Fairmont
[/B]
$1000 OBO for heads w/ cobra cams, sprockets, sec. tensioners, and chains
$1100 for shortblock w/ stock oil pan, stock balancer, stock flexplate, and new high volume oil pump
$100 cobra exhaust manifolds
$60 primary chains and tensioners w/ guides
$100 99+ timing cover w/ belt tensioner
$150 COP cam covers w/ coil covers
1979 Ford Fairmont
[/B]
Why part it? it looks purdy!!!!!!!!
1999 Trailblazer(wifes rig)
Dang!!! Some good parts and me without the $$$$.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
its sold already, and has been replaced with a navigator motor.
1979 Ford Fairmont
[/B]
