Topic: F.S. Explorer intake (polished upper).... (Read 1025 times) previous topic - next topic
I'm selling my polished Explorer upper intake and lower.The lower is not polished.I installed a modified (for appearance) polished explorer upper and my spare lower that I had bead blasted)Here's the description.....
Upper:Polished upper,no damage or broken ears,great shape.Looks really sweet under the hood....$150.00 shipped
Lower:rear passenger side upper to lower bolt hole has a few threads up high stripped.I used a slightly longer bolt and never had a problem with it.Second,the water tubes that run down the passenger side,the previous owner had put some kind of JB Weld or something around the threads of the water tubes where they meet the intake.I chipped at it and it will come off easily.No leaks,not an issue for the 2 years I used it.It has the ACT sensor hole drilled and tapped in the #5 runner on the lower.The water tubes are connected.All holes are in good shape,not stripped.$50.00 shipped.
$200.00 for the whole setup.No trades,sorry.I'll also include a polished 5.0 H.O intake plate for free.
Update......I have a thermostst housing bolt I can't get out and don't want to spend any time trying to remove,so,I dropped the price as a set,and on the lower alone,by $10.00.
By the way,If you want pics,send me your e-mail and I'll snap a couple after work and get them to you later today.
reduced $$
What are ya doing for shipping? Give me a total to 21144 and we might have a deal.
$150 for the upper....shipped
$50.00 for the lower.....shipped
$200.00 for all of it.....shipped
Pending Sale...................
Quote from: vinnietbird;182933
killer deal!
Thanks,I agree.
Just swapping parts all over, aren't you. I'll be next in line if you can't sell it. No reason to go with a better flowing intake for street use since these are fine up to around 5500rpm's where other intakes pick up. Let me know, will paypal immediately. Just (still) waiting on the machine shop to work on my block.
Oh, does this have the egr tubes in the upper?
1988 Thunderbird Sport
SOLD !!!  Yes,I'm changing a lot of parts.In the past two weeks,we've swapped the heads,added roller rockers,intake,8.8,water pump and front cover,E303 is going back in soon as well.Probably in 2 weeks.
