Topic: T3/T4 Turbo, 40Bob Header and TiAL 38mm WG Installed (Read 2631 times) previous topic - next topic
I spent Saturday installing the new header, turbo, oil lines and wastegate. Although I have a mysterious boost leak (I think its between the wastegate and header), everything is working GREAT. We took the car out for a spin, and the turbo is RIDICULOUSLY loud, even on the freeway people in other cars look to see what the noise is. As in, as loud as a semi truck. Just easing into the throttle, the turbo winds up so loud, sounds like a jet taking off. With the boost leak I can't get above 10 PSI, but up to 10 it pulls hard. I'll post some pics when I get a chance.
My exhaust consists of a 3" diameter elbow off the turbine housing, dropping down about 6", THAT'S IT.  It sounds like a John Deer at idle, sounds like a jet or semi when I get into the boost.  Heading over to my bro's tonight to pull the header and tighten down the wastegate.
Sounds like your getting mad boost creep(not good)put an exaust on there and she will run and pull much better.!!
Its not boost creep.  It turns out its an ignition issue.  One of my plug wires was not seated very well.  Still havfen't fixed it 100% but I did get 1 good hard pull out of the car and it was scary.
get a video of this thing from outside and inside, i want to hear that turbo SCREAM!
:birdsmily:
I have determined that I have an ignition issue.  I fixed it temporarily last night and did a pull, hit 16 PSI and backed out of it, scared the shiznit outta me, the car has never pulled nearly that hard!  I think I am going to replace all my plug wires to see if that fixes it.
Quote from: Inspiribomb;182794
Wait until you're making 24psi on a cold night. Now THAT is fun. :burnout:
User Rides
Post pics of your car here
we need pics!
His cardomain link is in his sig
last time i clicked on a cardomain it tried to fill me up with spyware
That and some of us turn off signatures "BECAUSE ITS GOT NAWWSS" :shakehead
PIcs are forthcoming.  I apologize for the cardomain link, I have no idea what is going on with it and why it would fill you with spam.  I've never had a problem.  But as I said before, I will post some pictures soon... ;)
i checked out your cardomain.... looking GOOD!  you've got a very nice car.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
Quote from: turboranger91;182951
I agree.  I love your engine bay, and your rims!!
