Topic: Cat not starting in mornings (Read 2671 times) previous topic - next topic
Here lately she just hasnt wanted to start without a little motivation.
It cranks real easy, got a new coil and ignition module. fresh tune up
My mind is tellin me fuel pumps
what would you guys say?
The T-bird or the Cat? See what your fuel pressure is before swaping pumps. I've done it and it sucks :hick:
Have you checked the battery and starter?
Quote from: thunderjet302;182610
Quote from: vinnietbird;182645
Haha Neither one of you read his post did you?
I read it,I guess I just didn't absorb what I read.I have an H.O Mark VII pump if you need it.
Dont believe the mark one will work. 83 is most likely gonna be different. and I got 2 pumps.
What's the fuel pressure?
What do you mean by "a little motivation"?
Quote from: CougarSE;182654
I thought it said Car not Cat:hick:
how old is the fuel filter?
by "a little motivation" do you mean you gotta pump the pedal a few in the morning?
little motivation as in starting fluid... but that has come to no avail and left me driving the bird.
Ill have to find my pressure checker or snag one from school.
How did it run once started?
it ran fine. it had a stumble every now and then, but i thought that was because of the py plug wires.
it had spiked 10 psi and bled back to 0
You ever change the fuel filter?
Are you talking about fuel pressure?
Only 10 psi???
If that's what you meant, then it's possible the fuel pressure regulator is bad.  Pressure should be 39psi and it should hold that for a while.
Try that first.
