Topic: Stock turbo is blowed up. (Read 2312 times) previous topic - next topic
I decided to seperate the exhaust on the cougar and found a lot of oil. Took the turbo apart and I think it is too bad to rebuild. It has a ton of endplay. I found some scoring on the shaft next to the turbine and inside the turbine housing where it would run.
    OK correct me if I'm wrong the stock Garrett turbo (I named my son Garrett) is a t-3 at a 42 trim. What are the other specs that I need to know about. What type of recomendations do you guys have for a mild upgrade that wont hurt spool time and will be good for 250 to 300.
250-300?  you can do that on a t3.  otherwise, a nice t3-to4e would be a good upgrade... even a holset wouldn't be a bad choice.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
I thought they were a .48 Trim...
I think it has 42 along with Garrett casted on it. I'll double check it. What is a good trim to go with a porteed and polished head, intake, and otherwise stock set up.
57 trim for you.
06 pontiac g6 gt
:birdsmily:
auto - 60 trim .48 exhaust housing
Manual-60 trim .63 exhaust housing
Send it to Charlie at Evergreen, He will fix it right up. Thought mine was beyond repair. He even turned it into a T3/T04E.
He is a great guy and does nice work.
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
And the winner is: (awkward silence).......Sleeper T-Bird
    It says A.R. 60  MR11 right on it. I'm not so sure about the exhaust though. Its not as conical as the compresor. I'll measure it tommorrow. To be honest with you I'm not even sure what that means. I understand the formula just not what it does for me. I've got a lot of reading to do.
How much is Charlie at Evergreen going to cost me. I found a rebuild kit for under $100, and I found a used T-3  50 trim for say 2-250 from a friend in Toledo. I trust him pretty well.
I had him do the t3/t4 thing and clip the turbine, and generally rebuild the entire thing and it was a little over $500.
He bored mine out for oversize bearings and balanced the rotating assembly.
1985 Thunderbird TC
Sounds like he did a lot of work for you. I just want a basic rebuild for now. I have a lot of other work I need to do before a lot of upgrading. You got a web link so I could get a phone number or e-mail address. I went to Garretts web site and it said the price of a standard rebuild was around 150 plus shipping. That sounded pretty cheap. I would like to look into your guy still.
Quote from: Superdavesds;182595
Good choice :)
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Yeah I thought cheap china knok off would be a bit too long winded.
AhhhhCraaap,  The exhaust housing is cracked. Dank it what now. Anybody got a t-3 housing cheap.
Cracked where? 90% of T3 exhaust housings are. If it's just around the wastegate hole, don't worry about it.
Garrett H.
Exhaust sound clip
Another clip
It,s around the hole but it is spider cracked really bad. It looks to me like it would make the waste gate leak real bad. No worry I can fix it.
    The next problem is the center section is rubbed up pretty bad where the piston ring seats at. The shaft had a little wear on it right around the ring. I get mixed reviews on this one. Some say don't worry about it just rebuild it and put in an oil restrictor if it smokes. others say theres no need for a restrictor as long as the oil drain is clear. and some say to throw it out and get a new turbo.
