Topic: Stock H.O. cam. Is it worth it? (Read 1460 times) previous topic - next topic
I have a stock h.o. cam laying in my garage and I was wondering if it`s worth swapping out into my tbird.
Whats the specs of a standard 5.0`s cam and an ho? I my just get an e303 cam and gt40x heads later. But I`m broke at the moment.
Children of Bodom!!!
It's an improvement,with the E-7 heads and headers.
The firing order is different than stock to.Really not worth the hassle on a stock 5.0.
If I remember correctly the 5.0 HO cam has a lift of 444 and a lobe seperation of 115. The "E" cam work pretty well with most any combo (n/a turbo NOS or Blower) and also the F cam with a 512 lift works good. Either will give you a nice old school sound and make decent power. Not sure of the specs on the 5.0 cam. If you really want it I will find out for you. I have it written down somewhere...
85 TurboCoupe. 306/DartSr's/Vic 5.0 Intake/B-25 Cam/Vortech YS trim/A9L Computer and Mustang Harness/ Pro M 77 MAF-50lb inj/TKO/15X10 Prostars/MMR Coilovers-90/10's-50/50's Chucks shock brackets/CHE Adjustable uppers/lowers. FR manual rack/steering shaft.
92 LX Coupe 306/Gen VII DFI/ No engine /TTI Race kit T-76/Comp cam/ 15X10 Prostars
I'd do it. All you have to do is swap to the HO firing order, pop in a set of HO injectors, get a HO speed density computer and you're in business:burnout:
Quote from: thunderjet302;182278
I think you missed he has no money.All that cost,unless someone wants to donate?
OOOOOO! donations would rule!!! I do have couch cushion change for the junk yard though. I`m scouting for 3.73`s interior harness parts, and anything else i can rob from the turds
Where you from?
I have a Mark VII H.O computer.Not free,but not expensive.I also have a set of 19# injectors.Again,not free,but now expensive.We can work something out if you want.
I`m from St.louis Missouri
Quote from: kitzdnm;182284
It's possible to get all the stuff for less than $100:hick:
Then again if one is broke that could be too much.
HO cam is nice. Especially if you have the stock shortblock with flat-top pistons.
pro-five-oh
do do know somebody with a 88 mustang parts car he`s using to put new frame clip on the frontend of an 89, I might just go with a compu cam and some descent heads
