Topic: Identifying ranger gears? (Read 1625 times) previous topic - next topic
I`m going to the junkyard tomarrow for ranger axle gears. I want to find 3.73`s and I know some had 3.55`s. How do I tell them apart with the axle numbers?
Children of Bodom!!!
there were several.  some trucks had the 7.5" and some had the 8.8".  i'm not sure what the combos were, but my 7.5" came with 3.45's.  i know that the 4x4 trucks use the 8.8".  the 7.5" could come with a gear as low as a 2.73.  basically what i'm getting at, is there are several different combos on them.  look at the diff tag... it will tell you every thing you need to know.  happy hunting.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
We pulled an entire rrear diff. and installed it in my buddie's '67 Stang.It came from a '96 Explorer and had 3.73 gears and Traction Lock.
4wd rangers had that along with the explorers and even some aerostar vans had them.
06 pontiac g6 gt
:birdsmily:
Not all Ranger 4X4s came with 8.8 trac-locs. I just sold a 90 Ranger 4X4 that had the 2.9L V6 5spd and it had the 7.5 w/3:73 gears but didn't have the trac-Loc :( That would have helped in the winter. Look on the axle tag, providing it's still there and if nothing has been changed.
Good luck hunting :D
John
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
That's some good info !!!!! Never knew they were available with either 4:10s or 4:56s!
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
yep sure were... just gotta look i forgot about the 4.56 gear set myself lol until recently when running idea's thru my head not related to the cougars.
