Topic: Quick Time Turbo Systems? (Read 2286 times) previous topic - next topic
Anybody ever heard of these guys?
http://www.quicktimeturbosystems.com/info.html
What only 1 turbo? A V8 needs 2 ;)
A buddy of mine owns QTT.  He live not far from me in Ky. I have sold servral of his kits and installed and tuned even more.
As far as a V8 needing 2. You need to rethink  that.  The basic T70 kit has made a stock GT40 crate more that made 215 @ the wheel  with 8.5 lbs of boost made 444RwHP and 480 tor.
 That ould be enough to split your stock block.
 Newt is a very straight foreward guy. Kit includes very nice parts and all parts are powedercoated/ Cermic coated.
Need any more info just ask.  I can provide you with dyno sheets and such.
  You will need injectors,Chip (SCT, SpeedyDyno), Mass air meter and 255LPH H/V H/P pump.
fastcat. Your turbos are they from them?
Man I are they saying they will install for 350 not bad if that’s right for under 3500 you got some serious  HP
Don't forget a tranny after 2 or 3 passes if I bolted it up to my current setup:hick:
Seriously though, I was just curious as that is a decent price for a rather well put together kit.
I assume 42 pound injectors would be good for a TFS head/cam/intake motor with this kit running 8 pounds of boost?  I already have a 255 pump.
Quote from: 5.8fastcat;182519
Well then hell 1 ought to be good then :D
I run MasterPower T70 turbos which are standard for his kits.
