Topic: mass air (Read 1004 times) previous topic - next topic
mass air
would there be any performance gains by switching to mass air??
(upgrades are in my sig)
mass air
Not based on the mods listed in your sig. You might even lose a little due to the restriction of the MAF.
mass air
Use the money you have set aside for a mass air swap on an Explorer intake OR port the stock HO intake.  Not worth the swap to mass air with your cam.  With your 3.73's and 1.7 ratio rockers I'm sure your motor could use a little more breathing room as the RPM's climb.
mass air
Quote from: V8Demon;181681
He already has a Cobra intake;)
Really with the mods you have you really won't see any improvement.
mass air
thanks guys, i was just curious. would like to upgrade the cam and a set of trick flows later on and then switch to mass air, she runs to good now to tear right back into her
