Topic: Fuse issue (Read 3548 times) previous topic - next topic
Fuse issue
My friend installed new deck/speakers in his 87 TC. Fuse #11 which powers the seats/stereo blows every time the car is started. Any suggestions as to what may be the problem?
:birdsmily:
Fuse issue
is that more like,,,,,,,,,
my friend installed a head unit and now the fuse blows?
besides,, your seats are not on a fuse.
Fuse issue
Well actually the seats use a fuse.. I don't recall which numbers. They are on a Circuit Breaker as far as I know?
The radio actually didn't work prior to installing the new head unit, and the seats stopped working as well before installing the new HU.
But yes every time I turn on the car that number 11 fuse blows. I've already replaced it a couple times and same story.
302 H.O Swapped.. Bolt ons.. Tremec 3550.. 4.10's.. 18's..
Fuse issue
UPDATE
I disconnected the deck completely and still same story.
Fuse issue
:burnout: 23027- I had a wire Issue a little while back. Just go over all the lines again it solved my problem, you also might seek help from members "JCassity", "Solttouch" they helped me out when I needed them,lol  :cougarsmily: :cougarsmily:
Fuse issue
Quote from: 23027;181630
Well actually the seats use a fuse...
nope, theres a big difference between a circuit breaker and a fuse.
Follow fuse 11 in the below pics and you see where it leads.  If you have any options per the diagrams, start troubleshooting.
two different situations have been described on when the fuse blows.  One of you says the fuse blows "every time the car is started" and the other says "every time i turn on the car".
In terms, which is it?  KOEO or KOER?  accy/ start/ or what?  It makes it easier to troubleshoot.
First i would be looking at power antenna since its on the same fuse as well as the amplifier if you have those options.  Look at the diagrams and you will see that fuse 11 covers a couple different options besides the radio.  as for the power seats ,, i would suspect someone has been hacking into a hot wire for power to something or another in the past and you have inherited the problem.
Fuse issue
also, since your seats keep jacking up and screwing wtih you, check out my diy link below and in there is a link to power seats with wiring diagrams.
Fuse issue
The fuse blows KOEO..
As for the wiring diagram.. I think I will have a tough time reading that..
I think I will get my mechanic to fix it.. He's had a few of these cars before. If he ends up fixing it I will let you guys know what it was.
