Topic: Trans tunnel opening pics? (Read 1552 times) previous topic - next topic
Does anyone have a pic of their trans tunnel opening with the shifter installed? I just put in my trans and I don't remember it being this far forward. py pic, I know.
Mine is every bit that far forward and I have a 3/4" longer sn-95 T5.  I just have enough room to stick a socket and extension onto the front bolts.
That's about the same position as my little 4 bangers T5 shifter.  Have you installed the driveshaft yet?  That may give you more assurance that it is correct.
Yup, mine have always been pretty far forward as well.
Ok, I just wanted to be reassured. The car has been apart for so long.
The driveshaft is another issue. Anyone know the minimum amount of the yoke that needs to be engaged in the trans? This is not the stock driveshaft and it looks to be short. I will have to go out and actually measure it. At the time I was frustrated and just left it.
I have to crush the rubber boot on the rear trans seal to get my shaft out.  The yoke rides right up to that boot installed.  Not sure what the minimum would be.
I will have to call Swarr Auto tommorow and find out. I only have about half to three quarters of the yoke engaged.
I'm pretty sure you want 3/4" - 1" of shaft left before bottoming out on the tail shaft.  I know mine is a hair too deep as I only have about 1/2" of shaft left, but my driveshaft is also flat because the car is lowered so no worries about the shaft going in further.
I know this is with the Rubber seal on there but here is a pic. It puts the shifter about where yours is. This is in my 84 Turbo coupe.
