Topic: Full Digital Dash installment (Read 1345 times) previous topic - next topic
Ok I am gonna be installing the Full Digital Dash from the base digital.
I have the whole dash off so I'm gonna run the wires which need to be ran..  I know there are two tach strap wires to run from the cluster to engine bay.  I also have a wire going from cluster to computer for the fuel piN #34.  Is there any other wires I have to run before I put the dash on?
.: Lastest :.
do you want full digi cluster diagrams and base cluster diagrams?
Did you replace your oil pressure, water temp and fuel gauge sending units?
I didn't change the oil, or water temp, only the fuel Didn't know u needed to change the oil and water...  So Im guessing I need to get those now * screams Dam it more parts to look for.*
Also jcassity could u please send those diagrams?
.: Lastest :.
Yeah, you've gotta replace all the senders...
Quote from: Thunder Chicken;181333
Find a Mark VII at a yard.  It'll have the senders you need.
