Topic: Cleaning up the inside of the Cat.. (Read 1405 times) previous topic - next topic
Well I took everything out of the cougar 1986 LS 5.0L .  Dash is completely off now. * Hopes he can get it back on because he took it off in pitch darkness *  Going to be running wires from the Computer to the dash for the full digital cluster.  Also I'm running new speaker wiring which can handle up to 1600watts lol.  Going to put 2 amps in the car 1 for the left side and one for the right.  Then have seperate amps for the three sub woofers which will be in the trunk along with the amps.  Going to clean out the air vents and fix the airholes.  Also gotta find that foam to stop the air going thru when you close the vent.  My Steering column is basicly out so I'm gonna take off the colunm shifter to switch to a floor shifter.  Im installing the tC Full center consule which my car didn't have and also the pass. side power seat.  Going to also install the power factory antenna while the dash is off too.  Alot of the work has to be done in 2 days so I can drive it again....  so lets hope I can get this done.
.: Lastest :.
Sounds like you have some work ahead of you.Good luck with everything.Are you installing new carpet while you're at it?Now would be a good time.
Not gonna go with new carpet.  Mines in great shape, so I just steam cleaned it along with the seats.  I just got my power factory antenna installed and it works great :D :D.
.: Lastest :.
Good luck... I had the dash off in the '87 and I couldn't get it together by myself.  I couldn't believe how many effin' wires were under there.
Well, nobody else has said it, so here it goes.
:ttiwwp:
I actually would like to see your progress!
:hick:
88 TC, Lots of Mods.
