Topic: Running waaaaaaay too rich (Read 2404 times) previous topic - next topic
I would have never believed this story if I didn't happen to me.  I drive an 87 cougar with a 5.0  Recently, it had been running quite rich.  I'm talking 4 to 6 mpg!  Not to mention it ran rough too.  So I picked up a couple O2 sensors thinking they were the problem.  I pulled my car into my garage, pop the hood, and get ready to jack it up.  I'm looking around the engine compartment, and I don't know how I even saw this, but I see something under my upper intake.  It looked like insulation. Great, I got a hitch hicker.  I pull out the little bugger's nest all out, and I examine the area a little closer.  And all I see is frayed copper wire.  :wtf: So now I pull the upper intake off and I find that this critter chewed up the wires going to the injector on cylinder #7  In fact, they were crossed.  :shakehead So I splice in some new wire, put the intake and o2s on and away I go.  Now, my car stinks, really really bad.  I'm pretty sure the cats are toast from running super rich for so long.  And now I'm burning oil in that cylinder.  All these problems from a mouse or chipmunk.  Like I said, I never would have believed it if I didn't see it myself.
So this leads me to the big question.  Should I spring for a new h-pipe with no cats or cut a square in each cat, bust out all the material, and weld it back togther?  Would the latter work?
Re: Running waaaaaaay too rich
I have a guttet cat H on mine. It works but I am not to fond of the sound. It has more of a melow rumble to it. I liked my off road H better.
You could bust the catalyst out and weld them back up i've seen it done a couple times, I wouldnt worry about a new h-pipe if you buggered up a cylinder.
I got an old tire iron and cut it right at the bend with a hacksaw ( a lot easier to cut than I had thought) .I used the rest as a long chisel with a hammer to bust out the catylist from the cats.No welding required.On 2 of the cats there was some wire mesh and a little steel wool type material along with the catylist.It does have a deep mellow tone.....until I hit the gas.
Quote from: vinnietbird
lol, mine too. I only smashed out the first 2 cats. so with HO stock headers, 2 cats, 2-chamber flowmasters, and 2.5" tailpipes, it sounds pretty mean. it's louder than my uncle's fox mustang :D
I killed them all.It took about an hour to get it all out.It sounds real good.I have generic turbo lers on it for now.They've been on for about 2 years.I also have headers and H-pipe (for the past couple of weeks anyway).
I used a 25' plumbing snake from Wal-Mart to pound out the remains of the pre-cats on my '88.  A tire tool finished off the big one.
