Topic: Control Arm Bushings WTB (Read 1029 times) previous topic - next topic
87 20th 5.0
need both sets of control arm bushings either OEM or Poly.
Payment method.... ill send you check or whatever.
i have references if you want,,:hick:
parts required asap, will pay for packing / shipping / time ect in getting them here.
ship to
Scott Cassity
hc83 box 70a
gap mills wv 24941
pm me with info ect, or call 304 772 4082
If a set were to magically show up one day, ill know who to pay.
I just got $50 poly's from summit...  why not just go that route?
1988 Thunderbird Turbo Coupe
If you want to use the car as a daily, you don't want poly bushings. I installed 'em in my 'Bird and it rides HARD how. Doesn't matter to me because I wanted to better the handling and don't mind the harsh ride in an occasionally driven (as in hasn't seen pavement in almost a year) car, but if comfort is your priority you'll want to go with stock rubber bushings...
Quote from: Thunder Chicken;180521
i was thinking poly for just the control arms.  The rest being stock rubber.  Would that be a good idea in the long haul?  Just poly on the CA's wouldnt effect ride that much being as everything else is rubber ,, would it>?
I can't say for sure as I installed poly everything (rack bushings, stabilizer links, spring isolators, CA bushings), but even still I think most of the harshness is coming from the CA bushings...
stick with the stock ones. do auto parts stores in your area NOT carry them?
1979 Ford Fairmont
[/B]
If you're talking about the front control arms, it is a resounding "YES!" that they will make the ride more harsh.  You will feel every expansion joint in the road.
Quote from: 32VFoxBird;180608
Honestly, i have not checked. I wanted to send my cash to a fellow member,, keeping it in the family so to speak. I can check tomorrow though, i was just hoping someone had a set.
Thanks everyone for the advice, stock CA bushings will be installed.
Have fun getting the old ones out. That was the hardest part for me. I like the feel of my Poly kit in my car but yes it more road road sensitive. That isn't a bad thing down here in the Hills and corners that I live in.
To get the old ones out, just cut through them sleeve, bushing and all with a saw-zall.
I have to cross ref these numbers to the napa sticky.
napa gave me this
front pn 2673351, 2.4'' od = 30bux
rear  pn 2673512, 1.9''od = 18bux
corect?
