Topic: some more pics. of my ride... (Read 3167 times) previous topic - next topic
here are some pictures...hope you like them. maybe give some of you guys some ideas. the car was a 84 bird with tbi v-6...I completely gutted the whole car, every wire, every bolt. rewired with a complete harness from an 83 bird that was v-6 carb, c-5....now it has a 306 (302 0.030 over) .498 inch lift comp cam, holley 600, -8 stainless fuel line from the tank to the carb, a c-4 with a deep alum. pan, rebuilt with a 2000 stall, a 87 turbo coupe 8.8 rear end , 4 wheel disc brakes, che tublar rear upper and lower control arms, holley elec blue ext fuel pump, sway bars from a turbo coupe, hood from turbo coupe, and...a hurst v-matic shifter, i love it slap it up for each gear, and hold on.....:bowdown: X
X
X
I dunnie see any pics. Just some text...
I see the pics. What color are you going to paint it. I see you have the molding removed too. Is it staying that way?
Jim
Nice work.
:burnout: Project Thunderbird : Quiet please restoring in progress!!
Looks good
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
Quote from: Ether947;182435
same here no pics just
 text
Quote from: SLEEPER T-BIRD 87;182500
 text
Are you using Firefox 2?
They show up in IE7 for some reason.
In FF2, if I right click on the text, it treats it as a image. Under right click menu there is a "View Image" option. Selecting that makes me sign in again, then it will let me see it.
Quote from: Ether947;182516
yeah im on firefox  I right clicked them and was able to view em.
I got firefox, and it shows them perfect for me
Where'd you get that tank????? I need a new one for my beasty :hick:
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Quote from: 1BadBird;182582
You might want a fuel cell for yours. It's going to be a hell of a lot stronger than mine is and mine will stall from fuel starvation if I floor it with less than 3/4 of a tank :hick: . The stock tank has no sump so all the gas sloshes away from the fuel pump pickup on a full throttle launch.
Ya, that's true. I should just get a fuel cell and get rid of the spare tire well.  Hmmmmmm 22 gal or bigger. :hick:
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
