Topic: Project Goldmember! (Read 14862 times) previous topic - next topic
Project Goldmember!
Reply #75
Quote from: blu84302;190376
I do pride myself in being an avid biker, but I'd rather drive the T-bird this winter, than ride the Harley.  :flame:
You need a winter beater so the T-bird doesn't rust ;)
Engine bay looks great as well. I had valve covers like that on my 88 till I rebuilt the engine and added cast Cobra valve covers. The chrome ones look great but are a PITA to keep clean. I swear I polished the  things once a week :hick:
Project Goldmember!
Reply #76
isnt this where the kickdown is sopposed to be connected? hrm?
Project Goldmember!
Reply #77
Correct, that is where the "kickdown" connects.  The Tv though needs true movement of the throttle.. that connection actually floats.  It starts to actuate at about 60% throttle.  Not gona work for a TV.
Project Goldmember!
Reply #78
gotcha, so used to geo's 78 cause the carb looks almost identical
Project Goldmember!
Reply #79
Here's what the motor sounds like.  You can't see it because it's night time in a parking lot and I have no hood lights yet.
5mb so dial up beware.
http://vids.myspace.com/index.cfm?fuseaction=vids.individual&VideoID=23165092
:pics-stfu:
 Project Thread with pics
Project Goldmember!
Reply #80
tiny carb! at least it looks it!
sounds great though!!
Project Goldmember!
Reply #81
That does sound great! Looks great too!
Project Goldmember!
Reply #82
Update:  She's been a little bad to me lately.  Just last night the ignition key locked up on me.  Had to drill the mofookie out!  Not cool.  It as 7 degrees outside and I was in a Speedway parking lot.
All good now.  Still runs great except for the heater only works on low and the duraspark issue.
Bugs are to be expected.  Once I replace everything... it'll be all good.
:pics-stfu:
Project Goldmember!
Reply #83
I have a question regarding your cam you listed 0.493 int/0.500 exh. with stock bottom end. did you have flat top or dished pistons installed? If I'm not mistken the most lift on a 302 ford is 0.488int/ 0.488 exh. due to valve damage to the pistons. I was just curious.
