Topic: Project Goldmember! (Read 14829 times) previous topic - next topic
Project Goldmember!
Reply #45
They look good. That's what I'm running on mine. Nice quality stuff. I was going to go with 1.7 Crane rockers but with a .533 lift cam (with a 1.6 rocker) I'd be smacking my pistons:hick:
Project Goldmember!
Reply #46
Here's an update.
It's just about done.
-I've got the carb off to put a new linkage shaft in it.  I needed the TV rod hookup on mine.
-A little bit of wiring, and a couple of gages.
-Brakes!  Don't know if i need a master cylinder yet but they don't work.
-Floor shifter.  I broke mine. :(
-I got a new (used) exhaust system.  Hooker super comp headers, Mustang H-Pipe, and two flowmasters.  All in good condition ready to bolt on.  220 bucks off of craigslist!  w00t.
Anyway, Here's some pics for your enjoyment.  I can't wait to post a video of her.
:pics-stfu:
 Project Thread with pics
Project Goldmember!
Reply #47
And some closer pics of the headers.
:pics-stfu:
Project Goldmember!
Reply #48
That's coming together nicely!
As for your shifter, I can't remember, are you running an AOD or a C4? Have you thought about an aftermarket shifter?
Project Goldmember!
Reply #49
It's an AOD.  What I'm really thinking about is a 5 speed.  That tranny has been in and out of more birds then you'd believe.  This is the 3rd bird that tranny has been in, and it's org. a lincoln transmission.
So pedals, 5-speed, and new gears for my 8.8 are what's comming this spring.
:pics-stfu:
Project Goldmember!
Reply #50
You need an AOD shifter then, the 84-86 TC floor shifter would be missing a gear.
But yeah, do the 5-Speed! That's what's going into my 84 project. I got lucky and started with a 5-Speed car though ;)
Project Goldmember!
Reply #51
Looking good :D
One question though [SIZE="1"]why isn't the engine Ford blue[/SIZE];)
Runs for cover.........
Project Goldmember!
Reply #52
i may be wrong, but doesnt an AOD shifter only have 3 positions for the forward gears? i understand its a "4-speed", but OD is elec/hydraulically controlled.
1979 Ford Fairmont
[/B]
Project Goldmember!
Reply #53
Yep *D*, D, and 1. The AOD is all hydraulic and the AODE/4R70W are electronic.
Project Goldmember!
Reply #54
The 84 floor shifter from the TC reads PRND21.  So it's still the right detonates for an AOD. It had a C3 in it with the 2.3L.
Guys must not be use to these 4 eye girls. ;)
If all else fails the project will wait til i get a ratchet shifter. :(
:pics-stfu:
Project Goldmember!
Reply #55
From what I've read, and seen in person, the shifter from a TC auto will NOT work on an AOD.
I've got one of each, they don't match each other's detents, although they look similar.
Anyone else corroborate this?
Project Goldmember!
Reply #56
Taken from coolcats tech page.
"All C3, C5 and AOD transmissions will use the same kind: with 6 detentes, or notches. You cannot use a shifter meant for an A4LD (4-cylinder) transmission, like those used in 1987-88 Turbo Coupes, since they have 7 detentes."
:pics-stfu:
Project Goldmember!
Reply #57
Yep you guys all got me. I was thiking of the A4LD shifter in the old 87 TC auto DD we had for years.
So he needs the easy shifter ;)
Project Goldmember!
Reply #58
It's d-e-t-e-n-t-s guys.. :p
It will be nice to see that car on the road.  It's a uncommon color, and is just, well....neat. :hick:
Project Goldmember!
Reply #59
Quote from: blu84302;178803
I want your ENTIRE interior......thats clean!
