Topic: smoking and backfiring after tune up (83 Cat) (Read 2686 times) previous topic - next topic
as it says, I changed plugs and wires cap and rotor....  and now it backfires, sputters and smokes and the cat. convertor is rattlin a bit
Any ideas?
Rev up it backfires and smokes..
I used the same Firing order as my SO bird
sounds like timing or ignition related then if it just showed up. Or it misses its master.
Best suggestion is to do it again.  Start at the button and work to the plugs.  It has to be somewhere in the stuff you changed.
:pics-stfu:
 Project Thread with pics
checked it again and its in the right order.
cats? the floor is gettin hella hot.
Why would it do it all of a sudden though?
Might be them clogged though? are they glowing?
floor got way hot. the pop im gettin is from the exhaust system
prolly the cats... Claude keeps tellin meh that a free-er flowing exhaust would help it alot.
So whats stoppin ya? Stang shorties, summit H, catback of your choice?
sounds like you went clockwise in your wiring insted of  counterclockwise
im pretty sure 5.0's plug wires are routed counter-clockwise, not clockwise.
1979 Ford Fairmont
[/B]
say huh? doesnt it spin CCW?
Quote from: 87thunderbirdBlackJack;178675
yeah i made a typo been a long day at work
but sounds like it is crosswired to me
yes, for v8's and 3.8l's.
1979 Ford Fairmont
[/B]
i got that its the same order as a SO 5.0its wired right.
my problem is it feels like the car cant breathe maybe a clogged cat. bad o2?
when im going normal speed it chugs and acts all retarded, then i tromp on it and it hesitates then boom it goes.
Does this car have a thermactor system?
