Topic: door panels (Read 1046 times) previous topic - next topic
door panels
Looking for blue or black door panels with manual locks and windows.also does anyone know where to find new belt stripping for the windows? TX 75420
[SIGPIC][/SIGPIC]84 Thunderbird/ 408ci windsor, vic jr. heads,super victor intake/ camshaft ground by Cam Research/Pro Systems 950 cfm/msd ign./hooker super comp headers/Full manual C4, ultimate converter concepts 5000 stall/ 8.8 w/4.33 gears,Moser 35 spline axles and spool/double adjustable upper and lower control arms/Strange drag shocks and struts/10 point roll cage/weld drag lites/28 x10.5"/UPR k member and control arms/coil overs. 1/8 mile to date 6.39-60' 1.35 "NO POWER ADDERS"
door panels
Year? Car? Trim line? Pics of the door panels you want?
door panels
Its an 84
door panels
Those sound like pretty uncommon door panels. You may have a tough time finding them.
There is some basic information on how to replace the dew wipes here:
http://www.foxtbirdcougarforums.com/showthread.php?t=8969
door panels
Do you know the part # for the inside dew wipe?
door panels
Turbo Coupe or base Bird?
I have a set of manual window 83-84 TC door panels. Pics sure would help though.
door panels
Quote from: racerjc;178245
No, but you may be able to use the same part for the outer dew wipe as well as the inner. It's been discussed before, but I don't recall anybody even confirming it.
I can't imagine them being too different, so you should be able to go for it.
They're made to a pretty decent length - I had to cut off quite a bit of them to make them fit my vent window-equipped doors.
door panels
Its a base bird A B trim on the door tag. But its a race car and the interior has been removed except for the dash. I just wanted something that looks better than a door with nothing. Although I am concerned that the arm rest may hit the roll cage. Im also in need of a dash pad(prefferably blue or black).
door panels
Dash pads are available new in Black.
I'll sell you my 84 TC manual window door panels with armrests for $150 shipped, dyed black (they are tan now) with SEM dye.
door panels
I know dash caps are available but who has the dash pad? I'll think about the door panels.
door panels
No, it's a real dash pad. The caps are for the 85-88 cars.
door panels
Decided to fab my own out of aluminum.
