Topic: Taking out the carpet question... (Read 1454 times) previous topic - next topic
Ok I got the whole car interior taken out, panels and head liner and the seats all out even consule...  My problem is how do I remove the carpet from the front where the middle of the dash is, its stuck I removed my ash tray and all, do I have to move the whole dash???
.: Lastest :.
it slides rearward  out from under the dash
I couldnt get it out from under there so I just made a cut in the back.
alright then I might need to make a cut...
.: Lastest :.
I just unbolted a few bolts on the dash and lifted it so my wife could pull it out.I wanted the new carpet to go in as it should,and loosening the dash made it real easy.Only takes a couple of minutes to loosen it.Do it right the first time.If you go to all the trouble to remove seats,and everything else,what's a few minutes to loosen the dash?
