Topic: Turbo Coupe Weight? (Read 3646 times) previous topic - next topic
Turbo Coupe Weight?
I read on NATO that the '87-'88s were 3415 lbs with the T-5.  What about the '83-'86 T-5 cars?  I know it's probably really close but does anyone have a number?
Turbo Coupe Weight?
Atleast 40 less I'd think because of the 7.5" insted of the 8.8
Turbo Coupe Weight?
take your car down to a s metal place or a track that has a scale, and weigh it yourself. everybody's weight varies.
1979 Ford Fairmont
[/B]
Turbo Coupe Weight?
Quote from: 84 Fila;177364
A 7.5" weights 40 lbs less than a 8.8"?
Turbo Coupe Weight?
Thats what I was told/heard
Quote from: Coolcats.net
While this axle is very tough, it is also very heavy, weighing about 40-80 lbs. more than a comparable 7.5" rear.
Turbo Coupe Weight?
Its been documented that the 8.8 weighs less than 10 lbs more than a 7.5 with no axles, brakes, or oil.
Also 83-86's weigh way less than an 87-88... like, 3000-3100lb range.
Turbo Coupe Weight?
No its only about 10lbs.
Turbo Coupe Weight?
Quote from: bhazard;177377
If thats all an 83-86 weighs... I wana see what I got mine down to now;)
As for the 8.8>7.5" in weight, I'm only going by what I saw on coolcats. If it's really closer to 10 LBS then it has been corrected in my memory bank
Turbo Coupe Weight?
i've never seen two cars of the same year/make/model weigh in the same.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
Turbo Coupe Weight?
aside from the bitching, there's actually some good info in that thread.
06 pontiac g6 gt
:birdsmily:
Turbo Coupe Weight?
thanks for everyones input!
Turbo Coupe Weight?
Its been documented
:pics-stfu:
Turbo Coupe Weight?
id like to know what my 86 weighs
maybe when i get the time ill head down to a truck stop(weigh in station i mean) and find out:hick:
Turbo Coupe Weight?
Weighed my 88 auto TC with every option except leather and moonroof. On a certified truck scale and a half tank of gas it was 3360lbs. Not too bad for the size of the car, I think.
TC#1- 2.5T- 10.14@134....9.76@138 with a 50shot
TC#2- Turbo BBF project
TC#3- parts car
