Topic: Dash lights (Read 1983 times) previous topic - next topic
Dash lights
Hello,
  I'm having a problem with the digital dash lights on my '87 Cougar XR-7. In the morning when starting the car, the dash gauge clusters will turn off and on intermittently. Sometimes this happens when I'm driving at night, and by lights on the dash I mean everything, gauges, light switches, buttons etc. The whole dash goes dark. Is there a ground or some other wire that is common on being loose? Have any of you had the same problem?
Only in America do we use the word "politics" to describe the process so well: "POLI" in latin meaning "many", "TICS" meaning "bloodsucking creatures".
Dash lights
With the intermintent, it sounds like a ground IMO
Dash lights
That's what I would think too, but I have no idea where to look for this wire.
Dash lights
Let me find my EVTM and I'll post the diagram
Dash lights
It could be the ignition switch as well.Mine did that when my switch started going bad.
Dash lights
These *should* be what you need
Dash lights
- Bad headlamp switch
- Loose connection at cluster harness(es)
- Bad ignition switch
- Bad cluster illumination relay
- Bad ground
Could be any of these.
EDIT: I have seen rare instances of the headlamp circuit breaker failing, where the lights would flicker on and off. You may want to replace that to see if it helps.
Dash lights
How about bad connection at the headlight switch.
Dash lights
bad ribbon circuit
Dash lights
LOL! how about I tear the dash out. HA :D  This weekend I'll give each circuit a look. It has to be one of those. I'll keep you posted. Thanks for the diagrams Fila!
Dash lights
Don't thank me, thank Jcassity. He sent me the EVTM
Dash lights
okay, I found what the problem was. It was the turn signal switch assembly. I haven't messed with the car in awhile and finally got to it about two weeks ago. The switch is so bad that if you push down on the turn signal switch a bit hard the engine cuts off and the dash is like  a blinking christmas tree.:shakehead  I have a new switch on order and should be here in a few days.
