Topic: Tryin to cheap out as usual--new rear end bearings...? (Read 1771 times) previous topic - next topic
Alrighty. Well I got the 3.73s on ebay, and found a highly and widely recommended local shop that apparently is very good with rear end gear swaps. I guess theyre also reasonably priced, gotta call and find out.
With 120k on the clock for this thing, is it likely theyre going to want to replace the bearings? http://store.summitracing.com/partdetail.asp?autofilter=1&part=RAT%2D304K&N=700+4294925134+4294839047+4294862355+4294900886+115&autoview=sku I found that kit, is that good enough if it needs freshening? Only thing it says it doesn't include are axle seals and I know neither of those are leaking.
Just something I never even thought about that was brought to my attention at a cruise-nite late this summer, wanted a 2nd (or many lol) opinion(s).
The axle seals may not be leaking,but if you're going to all the work of replacing the gears,bearings,etc.Swap out the end seals as cheap insurance.
Oh,PLEASE get rid of those whitewalls.LOL.
Swap out the seals.  What's the point of throwing it back together only to have it leak in 3 months?
If you're replacing the gears I would highly recomend you replace all the bearings and seals while you're at it. Otherwise those new gears may wear themselves out before their time. If you're gonna do it, do it all and do it right.
Stop being cheap.
Mkay. :hick:
HAHA vinnie every freakin time I laugh so hard that stuff starts hurting.
Hmm ya know I should probably post a more recent pic in the banner thread, you know, so the banner reflects accurately the current state of the car.
I WILL go down fighting. Dagonne it I will have you all hooked by the time theyre worn out!!!! :toilet:  Actually right now theyre more like brownwalls:hick: oh man laziness is BAD for cars lol
Hooked..................NOoooooooo.They do make good swings if you tie a rope around them and hang them from a tree.Or,perhaps they would look good on a '77  Lincoln.
You wont get the seals out without destroying them..  ;)
I've had a few high mileage rears apart and they have looked fine.  Just depends on the life it lived.
