Topic: problem solved!!! new question! (Read 4018 times) previous topic - next topic
I think I have a problem. I'm trying to get the old rack out, so i get the right size wrench(took for ever to find), a pipe and went to work. So i push push push then POP, comes loose so i go under the car keep cranking and relize the whole freaking bolt is coming out!!! Is it suppose to do that?
Now all it does is spin doesnt seem to be backing out any....
Uh...take a gander at the other side of the K-member and you'll see the head of the bolt ;)
AHHH. I thought it was a stud. Thanks chuck.
yep that solved that just have to get the steering shaft off, and the lines off and its out!!
Got the rack almost out, now i cant get the splined shaft to budge from the rag joint. Is there some special way to get it out??
did you take the bolt all the way out?
1979 Ford Fairmont
[/B]
yep
a little wiggle, penetrating oil, and some torque go a long way. you could also try just unbolting the rag joint from the coupler.
1979 Ford Fairmont
[/B]
rag joint is NOT gonna com apart, the bolts are in rough shape. ill have to get some more penetrating oil, and beat it it tomorrow. Thanks.
So,are you saying you're going to beat it off tomorrow?
the power steering rack hahha. Its time I got off my ass and got things done on this car, so I want the new rack in tomorrow, and new rear shocks in tomorrow.
O and my new fuel lines are in the mail. FULL MARK7 lines. no more rigging!!
I got it covered in pb blaster, and beat the  out of it with some punchs, chisels and flat head screw drivers. It won't budge.... Anyone got any ideas that don't involve flames?? the rubber rag joint wouldn't like that flames much
also how do i get the bolt sleeves out of the k member, because i need to get5 my new shorter ones in that came with my new rack.
Anyone?? I need help guys!
smashed the back of my head but i got it out!!
