Topic: need help with brumbrakes (Read 2199 times) previous topic - next topic
i had to replace my back brake lines and went to bleed them and i could not get any fluide. i checked the lines and block where they come out of and its all clear. i pulled the mane line off the block on the rearend and i get a small amount of fluide out of it. dose any one know whats rong?
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
Are the wheel cylinders any good?
i had to replace the pass. side and the driver side is fine
:birdsmily:
is the valve not centered in the prop valve? sometime with a major leak they will over center and cut fluid flow to the rear brakes
do u meain the hole in the side of the bolt and the block on the main line for the back brakes?
:birdsmily:
whats the prop valve? i dont know a lot of the parts names
:birdsmily:
Dem Brumbrakes can be tough.
Quote from: CougarSE;176400
LMFAO.
Hey Sleeper - is that your "sleeper" in your profile? :D
